There is a bug when using the “Is In” and “Is Not In” filters.
I have a table called curriculums that has a linked record field (many-to-many) called Work Instructions.
The idea is when creating a new record in the Curriculums table, the user can add or remove Work Instructions to and from the Curriculum record.
I have two queries created in the Work Instructions Table, one using the “Is In” filter and one using the “Is Not In” filter.
In the app, I have embedded the two table queries seen below:
However, both tables show no values in either table until there is at least one linked record:
Once I link the first record, then the table filters act as they should:
I believe there is a bug where the filters do not work for “Is In” or “Is Not In” until there is at least one linked record in the array.
Can someone take a look into this for me?
