Viewing Cameras from External Stations
Hey,
It appears for displaying a live feed from a camera from an App can only happen at the station that the camera is attached to. Long term could we make the live feed accessible from other stations?
thanks
-Matt
Hi @mcombs,
Thanks for the suggestion - is the idea that you want to run an application that references the live video steam at another station?
Is there a specific application that you had in mind?
Jake
Hey @jakerigos ,
You are correct. The idea was that we received a request from Industrial Engineering that wanted to observe the process as operators are using a pick to light solution. As of right now it would just be displaying the image in an external app.
thanks
-Matt
Hi @mcombs,
Is the idea that someone is always watching them or is it most important after a defect/issue occurs?
If you haven’t seen vision buffer video recording (capture up to the last 5 minutes of video), it may be worth checking out this KB article here.
Sincerely,
Jake
