Visibility of Custom Widget Usage
I have a feeling we had this capability earlier.
Anyway, it would be very valuable to see which custom widget is used by which apps. This would help us perform risk assessments and get a clear overview of the usage.
Simply click in a row of a custom widget (on a white space, not the link) and a panel on the right hand side will open with this (and more) information.
Thanks, Thorsten.
Yeah I can see it now. Earlier we could see this in the CW overview page.
Maybe a UI/UX improvement suggestion:
Currently, it seems like the interface clips the app list after three app names. It would be great if it could expand to show the full list.
Alternatively, a CSV report containing all CW data, with usage and other metadata, would also improve visibility.
@OlgaStroilova For visibility
I agree. You technically can, but that’s unnecessary many clicks. (After the three apps, there is an pill like +5 hover that and click the expansion arrows and you get a small modal with a full list.)
Yes, but if you have long app name, you dont even see the +X apps and the arrow to expand.
@OlgaStroilova This is something I would call a bug.
Thanks - let us look into this!
