Add labels on charts in Dashboard
Hi there,
How can I add labels in the charts created in the Dashboard section in order to have a better understanding of the KPIs?
Best regards,
Matteo Morosin
QA Manager Smith Optics
Hi @matteo.morosin, my understanding is that adding labels in the areas you’ve highlighted is not possible at the moment. If you’d like to share more about what you’d like to see in this area, please feel free to turn this into a product suggestion. I’ll tag in @stefan here in case there’s any additional insight our product team can provide here.
Hi John, Thank you for your reply.
Like in Excel, I would like to see the values of the columns over the columns.
Thank you,
Matteo
How can I switch this into a product suggestion?
I just changed this to a product suggestion and adjusted the title to match the new format. In the meantime, we recently release a few features for editing the formatting of analytics and dashboards. Check out these and see if any will help support your use-case in the meantime.
Hi @matteo.morosin, the next release (r281) will include the ability to show data labels on bars. See an example below.
Hi Stefan,
could you please include a screenshot of where is possible to make this change to add the label?
Thank you!
Hey @matteo.morosin, release r281 has not shipped yet. So you won’t be able to find that on your end.
Once it has, you will find the option in the formatting panel on the right under “Data Labels”.
@stefan I’m not seeing the data label for the bar that’s under the reference line. Is that the expected behavior?
@jjj Thanks for bringing this up. This seems like a bug. We’ll take a look!
@jjj Wanted to close the loop here: This will be fixed in the next release!
This is officially fixed in r284!!
