Add triggers to a single select widget
single select widgets with triggers could help us to create more dynamic apps , some times we have a single select and a button to execute some refresh function etc.
Hey Christopher – thanks for reaching out. I think we’ll be able to fit this into the next release, so keep an eye out for it in the next release! We added triggers to multi-select and checkboxes as well.
Hey All-
Triggers on checkboxes, Single, and multiselects are LIVE.
Check out this post about the new features in r230-
This happened because you asked for it! Keep the ideas coming!
