Additional Transition Options - Current Step / Step Group
Found myself creating a button several times to refresh the current step of an app I’m building, specifically to get updated “On step enter” triggers to fire without having to restart or go backwards in my app. I also have buttons like this on any step looping steps in my production apps in case the loop hits the consecutive trigger limit and needs a button click to resume looping.
It might be nice to have the additional options so the list reads like:
  • Previous
  • Current
  • Next
  • Previous Group
  • Current Group
  • Next Group
Then I can just but a “refresh step” button on my base layout and not have to keep editing these transition triggers step to step.
@jmlowden You are able to do this if you use “Go to Step by name” then app info, current step. This way you could put it on the base layout and have it be dynamic.
But I agree a route to current step feels more intuitive and would be a nice quick win.
I forgot I could use App Info in that way - thanks!
Good idea, but you have to make sure that the step name is unique.
Otherwise, you might be sent to a different step which does have the same step name.
