AI Agent Autosave
Hello…I desperately need an auto save feature (or at least an option to turn on auto save for certain agents). I just worked on an agent for 4 hours, took a lunch break, and none of it saved. I don’t think I need to describe how frustrated I feel for everyone to understand why it’s important.
Please consider adding this soon. (asap)
Back I go, to work on the same agent…
Hi Jade,
Ilana from the Tulip product team here. I’m really sorry this happened - losing 4 hours of work is genuinely awful, and your frustration is completely understandable. Thank you for taking the time to report this.
Agents should be auto-saved, but if there is an issue here we will investigate and get to the root cause. Can you shoot me a DM with the agent name and instance you are working in? I will make sure to look into this.
Hi Jade,
After looking into this, we noticed a significant amount of activity on your agents during that timeframe. One likely cause is having the same agent open in multiple browser tabs simultaneously. Since edits take effect immediately, changes made in one tab can sometimes conflict with or overwrite those in another.
To be safe, it’s best to stick to one tab per agent for future sessions. The good news is that agent versioning is coming in the next few months; this will provide much more control and a significantly smoother editing experience.
Hope this helps clarify things! Let me know if you have any other questions.
Best, Ilana
