When an app is exported from one environment and imported to another, any analysis displayed in the app is not carried over. I would like to see this function the same way any linked tables do. The analysis should be copied over with the apps as well. Currently, the analysis are lost and have to be reproduced in the new environment.
Hi @japrice ,
When apps are moved across instances, the analytics also get moved over. These analytics will not show any data unless the table that an analytic is built on has records imported or added to it. If the analytic is an app-based analytic, you would need to complete the app to have the analytic reflect the completion data.
Thanks!
