Hello all,
When I use the dev-player, I’ve an annoying transparent box if I hover the pointer over the bottom-center. I’m then fighting to input data in this area when I test my apps.
Am I the only one facing this issue ?
Hello all,
Hi Patxi,
I agree that box is annoying. This looks like a bug with the Test environment feature.
I’ll update this post when there’s an estimated timeline for its fix
In the meantime, when you need to input data into an app, you could try making the preview screen as big as possible by dragging the bottom of the screen down, and this should minimize the real estate that pesky box takes up. Hopefully that helps in the meantime.
Best,
Kailey
Hi Patxi,
This will be fixed in r200
-Kailey
