Add "Display: none;" Option to Widgets
It would be great to be able to change whether or not a Widget was visible. Ideally controlled by a variable.
Thanks!
That would be very helpful! We currently do work arounds by layering, but sometimes that doesn’t work if we need to be able to interact with the widget with more than a button click.
Similar to item 6 in my Oct 2021 post here: Layers in App Editor - #8 by aaronbroussard
Bump bump bump bump :slight_smile:
Variable controlled Display: None, or z-index control would by a massive upgrade and all around game changer IMO.
also see:
Dynamically hide a button/object based on a field - Product Suggestions - Tulip Community
Hide button on Steps, click on print button - Support, Troubleshooting, & Help - Tulip Community
Hide objects like single select - Support, Troubleshooting, & Help - Tulip Community
Hide button in tulip - General - Tulip Community
