Automation Expression Editor Improvement
I was setting up an automation to send a basic email out with a table query result from a connector and ran into an issue where it seems there is no ability to create a new line of text within the current automation expression editor.
In the app environment the editor allows you to accomplish this with \n, but in the automation environment it does not work.
Would like to have this fixed so that emails generated by automation events can be formatted more easily.
This screenshot is after “\n” has been entered the editor saved, and then going back in to delete the “\”. This is the same method in the App environment.
This is the result from the above editor
Thanks for the feedback! Forwarded to the team - we’ll see if we can add this one in quickly.
