Adding New Lines in expressions using Variables
Hello,
Whenever I input a variable while adding new lines, it keeps changing the variable to the string “e0”, “e1”, so forth and so on. Is there a way to add new lines and keep the variable?
Hey @gleeTICO,
Can you give me a little more context around what you are doing?
When you talk about lines you are referring to rows in a table, right?
Can you screenshot the trigger you are writing to that table with and we can work through this together?
Hey, I figured it out @Pete_Hartnett,
[Tip of the Week] Adding Line Breaks in Emails - General - Tulip Community
The forum above is the solution that I needed. Thanks for helping though.
Awesome!
Let me know if anything else comes up!
