Best Deployment methodologies from one Env to Env
If I change a step or table, can I only deploy the specific step or table changes to Another environment? is that possible?
Is there any article on the deployment for the Tulip from one Env to Another?
Hi @psp316r , have you seen this series of articles in the knowledge base? Export & Import Overview
Hi @kevin.kononenko ,
Could you please clarify what will happen to the app and the users assigned to the Station upon deployment?
Will there be a station assigned to the imported App or need to manually assign Apps and Users to Stations again?
I ask this because:
If In Instance(1,2,3) an App will have Stations and Users already been configured,
If I want to Deploy the App Developed in Instance 0 to Instance(1,2,3) how can I deploy so Stations and Users assigned to App in Instance 1 Will Remain same to the Newly Imported App from Instance 0 to Instance 1.
