Problem:
While working with connector outputs, Tulip developers frequently have to rebuild large pieces of applications when parts of the output model change. In complex apps this can make it so that you need to update dozens of triggers in order to add one column to a model. In addition to being time consuming, this can be very error prone because of the complexity required in these use cases as well as the general user experience with objects not being great.
For an example, if my app currently uses a list of Work Orders (Model v1) and I need to update my ERP integration to use Model V2 with additional keys, this will require completely blowing up my apps which use this model.
Potential Solution:
If Tulip object logic allowed for addition of keys so that Work Order Model v1 could be stored into an object of Work Order Model v2, it would make it significantly easier to cutover these changes.
// Work Order Model v1
id,
item_id,
quantity
// Work Order Model v2
id,
item_id,
quantity,
upc_code
