Building a "Productivity" analysis
Hi all,
I would like to build an analysis that calculate the productivity of my machine.
Productivity = Number of INPUT Products / (Time machine state = running + Idle)
I have 3 different status on my machine :
  • Stopped = machine is shut down and not in production
  • Idle = machine is capable to produce but don’t produce
  • Running = machine is producing
I tried to build this analysis but didn’t succeed.
Any tips on how to do that ?
Thanks !
Paul
Hi Paul!
Do you mind sharing a little more about what you have tried so far? If you can show what you have in the analysis and any errors / results you’re getting from it, that can help us find a good solution!
Are you using expression editor to calculate your productivity and storing that in a variable? If so, you should be able to use that variable in an analysis to visualize it!
Hi Beth,
Here are some picture of what I already tried to do in the analysis editor :
I tried to use an expression but didn’t store it in a variable. Is it possible to do that in the analysis editor ?
