Hi Team,
I really appreciate the screenshot functionality that Tulip provides within the app—it’s been very useful. However, I noticed that this feature isn’t available when executing machine or device triggers.
Would it be possible to extend the screenshot functionality to work during these triggers as well? This would greatly enhance our ability to capture and document events.
Thank You.
Hi @jay.shah,
Thank you for the feedback - we’ll take a look and get back to you on the feasibility of this. My guess is that the trigger flow only runs linearly and will not execute the trigger app screenshot while executing another trigger.
Sincerely,
Jake
Are you still looking into the functionality of allowing the capture of a screenshot from a device input? If not is there a way i can use the image input to activate off of a barcode scanner vs having to hit the capture button on it?
