It’d be very helpful if we were able to move logic into more locations. For example: I’m unable to move logic from the general “Triggers” location to the “On Step Exit” location.
Hi @ashchav20 it is now possible to change the event of a trigger between different categories. For example, you could change a ‘On Device Output’ trigger to be ‘On Step Enter’. Does this solve your issue?
Yay! Thanks for following up, this will be very helpful.
