Custom holidays setting
even though I can define working days it’s a little pointless to use the US specific holidays when the factory is not located in the US. Is there an option to define custom holidays?
Kind Regards,
Oliver
Hi Oliver, agreed that this has been a long-term limitation in the platform. There is no good way to define custom holidays at the moment. We do not have concrete plans to work on this feature yet, but any future solution would certainly encompass this as well as a series of other improvements.
Hi @kevin.kononenko,
I would appreciate features to:
  • push the holidays from our ERP system into Tulip via a REST API
  • use the holidays in triggers
  • use the holidays in expression logic
  • use the holidays in analytics
Kind Regards,
Oliver
