Custom widgets do not appearing on printing
Hello dear Community,
I am using a TULIP instance in release r301.1.
It seems that since this release r300 (or the one before), custom widgets don’t appear anymore in printing generated by the trigger action Print Steps > Print.
After printing:
It is something new, before, custom widgets were on printing.
Is it just a bug and it will be solved in the next version or is it a decision then I will find another way to display information?
Best regards,
Rémi Bayon
Hi @remi.bayon -
Thanks for bringing this to us!
This is actually a known bug from the latest Player release (Player 2.7.0) that the team is actively working on fixing. It will be resolved in Player Release 2.7.1
Just following up that Player 2.7.1 Release - January 2025 is now available and this bug was indeed resolved in this release :slight_smile:
