Delete button for each variable are greyed out
Hello,
I’m having an issue with deleting variables. When I click on the 3 dots, it shows the delete option but it’s greyed out. What can I do to resolve this?
I already know the answer. I found out that if the variable is in use in any part of your app triggers, you won’t be able to delete it.
Hi @OREJ - Yes! I am glad you were able to answer your question here :slight_smile: Happy Tulip-ing :tulip:
You can always go to the variable menu in your app
and then see where certain variables are used. That can help you find and clean up any that you want to delete!
