I don’t think it is. I’m not sure if I understand where to find this
hello @MJE0204, you should now be able to display the variable Operator Options in your app. you can go to Text > Variable to display it (in my case, it’s called Options):
here’s what it’ll look lie once you run the app:
also, I would like to point out that the filter.0.field you shared here is pointing to the id of the table, I assume you’d like to point it to the name?? is so, you’ll need to change that to the column xslfx_operator instead of id.
finally, could you also share the Outputs of the Connector Function to confirm you’re getting the records in the Connector Function??
also, this could be really quick to fix in Office Hours!! if you’d like to join, here’s the registration page: Tulip Office Hours (North America) | Tulip.
Gio, I made the xslfx_operator update and tried displaying the array as you described and it does not show data the same way as your example.
I registered for the office hours., and hope to work through setting this up and understanding connectors and this type of app setup fully in a virtual meeting.
Thank you
