Dropdown menu shows at top of screen
I have a large monitor that runs Android. When I run tulip apps on the Tulip Player on this, all dropdown menus open at the top of the player window instead of where my menu is located. This doesn’t happen on the web app. Is this a feature that can be changed?
Hi Hira!
So the webpage running the Tulip App is rendered through the Android System Webview component, which comes preinstalled with Android. The implementation of how a HTML select is rendered is dependent on this rendering engine, and not necessarily something on the Tulip Player side of things.
Do you by chance have an Android update or an update to the Android system webview app? Updating may potentially resolve this if so!
