I need a drawing of the New Edge I/O. A “.DXF” or a “.DWG” would be great. I am trying to lay out an enclosure and need to see where the DIN mount is and the connectors are with dimensions.
Related topics
| Topic | Replies | Views | Activity | |
| Edge IO mounting options | 2 | 355 | August 1, 2022 | |
What size/length/type of screw is used at the four corners of the Edge IO
0 | 18 | October 3, 2025 | |
| Edge Device Management (please add description and download button) | 1 | 65 | October 1, 2025 | |
| Status of EdgeIO in machine triggers | 1 | 98 | June 10, 2024 | |
| Edge IO HDMI will not work | 8 | 202 | June 5, 2025 |
