Has anyone used Edge IO device in LTS environment? Just wanted to hear out the experience of using it , specifically using Fluke multimeter.
Hey @aquadirk -
I know of at least 2 customers on LTS releases currently using Edge IO in LTS environments, but not necessarily in GxP use cases. I don’t know of any using fluke meters, but I’ll ask around.
Thanks Pete, out IT team is curious to know how Edge IO is restricted to private cloud only. If you could share your insight.
Hey @aquadirk -
No real additional limitations or challenges you should face with on private cloud vs. a cloud deployment. Private cloud is technically very similar to the Tulip cloud (its just private
) so you won’t run into any additional limitations.
