Hello all,
I have deployed in my shopfloor 14 EDGE IO to do data collection for product traceability.
I encounter some issues with the EDGE IO.
I have sometimes EDGE IO that are being disconnected from the network.
It is never the same EDGE IO (so I discarded a faulty EDGE IO possibility).
Once the EDGE IO is disconnected, I have to manually reboot (turn Off and On) the device in order to reconnect it to the Network.
This is very annoying because this type of issue generates important loss of traceability data.
For example on the picture below :
I have a support ticket (#22172) open on this issue since 1 month now but don’t manage to get a solution from TULIP support.
Does anyone have encountered the same issues with EDGE IO disconnection ?
I’m thinking about replacing this devices with other Iot Gateway devices that are able to run Node RED. Does anyone have tested other similar devices ?
Thanks a lot,
Paul
