Currently Drivers configuration for Mitutoyo U-wave is enabled on Tulip Player configuration, however, this feature limits us to have one receiver per station, and since I cannot run multiple apps at the same station, this is equivalent to have one receiver per app, assuming we want to run multiple apps at the same time.
I would like to suggest to include that driver configuration in the gateway as well, so multiple apps can be use having only one receiver.
Thank you!
