Hello Support team and everyone,
I would like to suggest one thing about U-WAVE-R. When I connect U-WAVE-R to an Edge IO, we can enable U-WAVE-R driver on the portal and it allows us to get a measurement value only from “Caliper or Depth gauge” trigger.
My suggestion is to add a Device ID of Mitutoyo U-WAVE TC. U-WAVEPAK can choose to output a Device ID. So, we will identify the correct gauges to get a measurement value. Now device.output has only data property. Please add Device ID property.
Kind Regards,
Akira Takahashi
