Export device uptime data to csv
Hello.
I want to export device uptime data to CSV.
It is possible?
Best regards,
hello @Akito, thanks for posting!!
it’s currently not possible to export Device Uptime to CSV, would you mind sharing more details on what you’re attempting to achieve??
one solution I would suggest is creating a Table in which the Device uptime is stored, similar to this: Live status of apps: display status/ pause that is visible in station overview on dashboard - #2 by gio, as you can then export the Table:
would this work as a solution?? thanks!!
