Features for Analysis table - Sort, word wrap, column rename
Configuring the analysis widget with an analysis in the table display format currently leaves a lot to be desired:
Add field sort: sort by date fields, ID, etc. on step enter
Add word wrap for headers: Having the user adjust analysis table columns on every step enter to view what they want is not ideal
Add field re-naming: field names get unnecessarily long, especially when you add table record items to the analysis
I strongly recommend implementing header wrapping, as it significantly improves readability especially in cases where there are many columns and the column names become difficult to read. I believe this enhancement would be very beneficial and worth considering.
Thank you for your attention.
