Floating Keyboard on Android devices
Annoyed by the Tulip Player screen shrinking every time you want to type on your Android device? I got a small trick for you.
GBoard Floating Keyboard will keep you app size with it’s original size.
What to do?
  1. Install the Gboard App from the Play Store on your device.
  2. Set Gboard as Default: (For Zebra device)
    a. Go to Settings > System > Languages & input > Virtual keyboard > Manage keyboards.
    b. Enable Gboard and disable other keyboards.
    c. Select Gboard as the default under Keyboard settings.
  3. Enable Floating Keyboard
    a. Tap on any text field to bring up the Gboard keyboard.
    b. Tab the four squares icon on the top left corner.
    c. From the menu that appears, select Floating. The keyboard will detach and can be moved anywhere on the screen.
