Formatting/Styling functionality : "Multi Select" vs "Single Select"
Hey Team,
I noticed that Tulip has some formatting functionality which is available in “Single Select” inputs but not available in “Multi Select” input. Is it possible to provide all the same formatting functionality in “Multi Select” input same as “Single Select” inputs?
See below screenshot for example :
Functionality in “Single Select”
Functionality in “Multi Select”
Thanks
Hi @jay.shah
Thanks for raising this issue! We know there are a few minor inconsistencies between these widgets. The multi select widget does not have the same wrapping of label text, and is missing some border styling functionality. Are there any other styles you are specifically trying to apply to your multi select widgets?
Cheers,
Sara
Hey Sara,
It would be nice to add all the functionality which we have available in single select input, but at least for starter if we can get boarder and label, that would be nice to start with.
Thanks.
Hi @sara_t
Also Multi & Single Select still have way different dimensions when set to the same Font size than a regular text input. (They are only the same on size 40)
(e.g. font size 24:)
Also Text and Number Inputs cant have a border radius (single select can…)
