Multiselect in LTS12
Hi community & tulips,
I am evaluating LTS12 upgrade and noticed something puzzling with the multiselect widget.
In our design we have made a multiselect available with a defined space and white background.
In LTS 10 it was presented like this following the design:
In LTS 12 it appear to resize the assigned area and background based on the choices available:
I can make a white box as background to restore the design, but does anyone know why the multiselect widget now do not follow the sizing configuration? I also fail to locate the release note entry that would indicate that the change was made…
thanks in advance
Asger
P.S. No comments on the typos in the test data :slight_smile:
Hi @ASharp-J ,
Thanks for flagging this issue! I’m a product designer here at Tulip and have been investigating this. What you’ve reported certainly isn’t expected behavior for this widget’s bounding box.
After checking with the team, we have identified it as a bug that must have occurred when we were working on input widgets for LTS12. I’ve gone ahead and reported this so the team is aware and we’ll fix it.
P.S. What typos! :see_no_evil:
