Get Started with Digital Work Instructions
Hi everyone! Last Friday we published a use case guide on the Knowledge Base about digital work instructions. This overview covers the following:
  1. What makes digital work instructions different from paper?
    (Spoiler: just about every advantage of technology)
  2. Making work instructions part of a composable solution
  3. How to get started:
    What is the reason behind deploying digital work instructions?
    What issues do you hope to fix with digital work instructions?
    How can work instructions apps help your process?
Not only is this article great for preparation and deployment, but it also adds context to work instructions for impacting many other areas of your operations.
Read up on this use case here: Digital Work Instructions Use Case.
You can also find other use case guides in the Use Cases by Solution section. We’re actively rolling out more, so stay tuned!
