How can I easily get readings from a Bluetooth pressure gauge into Tulip?
I have a Bluetooth pressure gauge, and I’d like to see the pressure reading directly inside Tulip.
Is there an easy way to do this? Do I need any special device or setting in Tulip to make it work?
Thank you.
