How to implement nested conditional control logic using triggers?
I want to implement logic similar to the following using triggers:
if ( A) {
    output = dosomething(); // like run a connector function and get the ouput.
    if ( <predicate related to the output> ) {
        pass;
    else {
        pass;
} else {
    pass;
What should I do?
could you provide a use case?
Your code just does something if A and then pass in any case.
You could just put two triggers in a row. the first checks for A else pass.
The second check for output from the first (dosomething) and if so, it does something else.
Or you can use an if(@variable.b = 1, true, false) in an expression inside of an if/then clause…
So nesting is possible but most of the times not needed (and also in programming not always good practice).
An actual use case would be helpful!
Thanks for your reply. I want to invoke a connector function, which may return two different types of data, and I need to perform different operations depending on the type.
So in the first trigger clear the variable and call your connector.
Then use a second trigger to check the connector output and tacke action on this result.
This will also make it easy to maintain
Welcome to multi-trigger hell…
This is exactly how you would do it in Programming…
e.g.:
if(A) then {
   result = getResult();
if(result = B) then {
   doXYZ();
} else if (result = C) then {
   doABC();
What would you prefer?
… to be able to treat it as single block that does not require me to do a deep dive every single time some app logic needs to be revisited for whatever reason.
Here is an example of using an IF expression within trigger logic where I didn’t want to create another trigger with conditions based on whether the Barcode Parse 2 Variant was blank (as opposed to null), which would defeat my LINK function.
The unexpected result without this insertion was that the SKU(-Variant) Lookup displayed the SKU followed by “-” and nothing after the hyphen, which doesn’t work when we lookup disposition based on that SKU(-Variant) Lookup variable.
Does it mean that multiple triggers will be triggered sequentially, not in parallel?
Triggers are always evaluated sequentially, with the first condition set (if/if-else) satisfied within each trigger being executed and the actions under that condition set being executed sequentially, potentially concluding with a transition (which escapes any subsequent triggers).
