HTTP Connectors - Issue with Video
Hi @SydneyDoyle and @John
I am going through this video in the below link for HTTP Connectors:
https://university.tulip.co/http-connectors/47033
I found some issues while practicing on Trial Version:
  1. When I am selecting Text=> Variable=>Data Source, I can see all variables I created and can select Object Variable “Weather”.
  2. Where as when I am selecting Embed=>Interactive Table=>Data Source=>Variables are not showing and coming as blank
Can you please help here if I am doing anything wrong. appreciate it.
Regards:
Vineet
Hi @vineet143
did you try to select an object or an object list to your table?
A Table is actually a list of objects, where every single record (row) is an object.
I cannot see anything to select there… but same is working with When I am selecting Text=> Variable=>Data Source, I can see all variables I created and can select Object Variable “Weather”.
Yes when you try to use an interactive table only variables of the type “Object List” will be displayed.
Other Variables have not the structure, that is needed for a table.
I am having the same problem! I got to embed an interactive table and the “weather” variable is not showing, even though I have followed the steps exactly.
