Ignition OPC UA and Tulip Integration
Hello Experts,
I have established the communication between Ignition OPC UA and Tulip with the OPC Data source.
Right now, I have done some setting’s below,
Security:
Runs on: Cloud Connector Host
Type: OPC UA
Server:
Agent URL:
Authentication Method: Username
                   : Password
      Security Mode: none
with this setting communication established between tulip and ignition.
but customer requirement is Authentication Method: X509 and Security Mode:SignAndEncrypt
for the above requirement require Private Key and Certificate, so I have generated the tulip certificate and Private key through Git bash.
but communication is not established.
please let me correct what is issue with above settings.
Regards,
Kiran Kale
