Introducing the Scheduling Custom Widget in Library
Exciting News: Introducing the Scheduling Custom Widget!
Hello Tulip Community!
We are thrilled to announce the launch of the Scheduling Custom Widget—a feature many of you have been eagerly awaiting! This new widget is designed to optimize task scheduling and resource allocation, making your operations more efficient than ever.
What is the Scheduling Custom Widget?
The Scheduling Custom Widget allows you to easily assign tasks to specific resources and time slots, ensuring that your operations run smoothly and efficiently.
Why We Created It
We heard your feedback loud and clear. Many of you have requested a more flexible and agile way to manage scheduling within Tulip. This widget is our response to your valuable input, aimed at enhancing your experience and helping you build the right solutions for your operations.
How to Get Started
To start using the Scheduling Custom Widget, simply head over to the app editor menu bar where you can access and integrate this new feature into your workflows. For more detailed instructions and tips, check out our support documentation and explore the Tulip Library for additional resources.
Join the Conversation
We invite you to share your experiences, ask questions, and provide feedback on this new Custom Widget.
Thank you for being a part of the Tulip Community. We can’t wait to see how the Scheduling Custom Widget enhances your operations!
Hi, that is really awesome widget!
Im testing it now but Im missing one thing or maybe I’ve just couldn’t find it. Is there a way to Complete Task manually so it disappear from the timeline as completed?
Hey Jacek,
Glad to hear that you liked the widget.
This capability is not available at that stage on the widget. However, do you think that adding the capability for the widget to only show tasks of certain statuses (e.g. Scheduled, In Progress) and to filter out other statuses (e.g. Completed) would work for you?
We could work on a v2 to add this.
Thanks in advance for your valuable feedback.
That would work for me, However, the question that remains is when the task is completed. Flexibility should be provided:
  • task should be automatically completed when current date time is higher than completion date
  • manually option to close the task (change status to Completed)
Thanks for the feedback, we’ll try to come back with an iteration of the widget ASAP
Hi Jacek,
Thank you for your suggestion. The feature has been implemented, and it is now available for download.
Regarding the task completion flexibility: while the task doesn’t automatically change to “Completed” when the current date and time exceed the completion date (to ensure reliability), we have added a manual option to close the task by changing its status to “Completed.” Additionally, we have introduced a new filtering option that allows you to filter tasks by their status, making it easier to manage tasks.
You can find more information here:
Let me know if you have any further questions or suggestions!
Best regards,
Mihaly Gyurkovics
Hello, I tried adding this widget but I’m getting this error:
Hey Anthony, sorry to see that you were not able to download the widget.
Since then, did you manage to install it and try it out?
Let me know if I can help.
Hey Hugo,
It seems to have been resolved after an update.
Thanks for checking though!
Wow, we have been looking for a long time for this kind of tool. Looks nice. Wonder if it can be hacked easily for week planning….
It is a very useful widget!
But I agree with Chris that a option to plan weekly would be awesome. Also I am missing a way to filter the tasks by user or location. Is there a chance for another iteration? Thanks in advance!
