Please create the ability to set the default camera to be used by the app player on an ipad / iphone to either the back camera or front camera.
Hi Todd! Thanks for the request here - just to clarify, are you using the input image widget or the camera widget?
Hi Beth, I’m using the Camera > Barcode Camera. I realize the user has the option to toggle between the cameras but I’m looking to set the default to the back without needing the user to toggle.
Isn’t the default the main (back) camera?
I have a barcode scanner app on my iPad and it’s always the back camera?!
Or does it remember the last setting?
Edit:
It seems to remember the last setting.
Thank you this is useful to know! On first launch it came up as the front camera as standard.
