ISO Configurable Date and Time Formats
Looking for configurable date/time format(s) that adhere to GxP date/time guidelines. Typically: ddmonyyyy (22may2024), 24hr time.
@ZAP @cpuzzo @michaelrcody
You can define the Date and Time Format at the instance level in your Settings while logged in as an Account Owner.
However, this is a global setting and if you want to create multiple or localized date time formats you will need to utilize the DATETIMETOTEXT function to store custom formatted timestamps into text fields.
Happy Tulip-ing
