Issue in accessing Tulip app builder site in EDGE browser
Hi Team,
I’m facing intermittent issue in accessing the tulip app builder site via edge browser. it says below attached message. but when i click logout and login it works. is it something a bug and non-compatible with edge browser?
Regards,
Kasilingam
Hi @Kasilingam.samy -
The error you are seeing suggests this may not be an Edge browser issue, but rather that you have another tab open on your Edge browser with the Tulip Player open. If you close that Player tab, the error should go away.
You also may have inadvertently logged into Player on this browser ( e.g. by registering a display device in the browser), and then if you try to use it as an admin without first logging out, you can see this error as well. Logging out then logging in should also fix this
Let me know if this helps you!
