We’re excited to announce the 14th release of the Tulip Library!
The Library is a set of apps that can be added to your account and used out of the box. Each App comes with an installation guide and a video describing how the App works and what it can be used for.
If there’s an App in this list that you’d like to use, click on the App’s link below and install it to your account today!
Release 14
Equipment Logbook App Suite (Video) :
The Equipment Logbook App Suite shows how to use multiple Tulip apps and a shared data structure to create a digital logbook solution. Configure the app suite to reflect your equipment and processes.
The Equipment App Suite contains 4 apps:
- Equipment management - Add, edit, and disable equipment selections for the equipment logbook app.
- Logbook management - Add, edit, and disable logbook fields.
- Equipment logbook app - Guide end-users through adding and correcting logbook entries, including equipment statuses.
- Equipment logbook review- Review logbook entries and visualize progress with real-time dashboards.
Try the Equipment Logbook App Suite here →
M365 Excel Unit Test (Video) :
The M365 Excel Unit Test allows you to connect and pull data from your Microsoft Excel spreadsheet into Tulip. You can add a new worksheet, look up specific cell values, create tables in the worksheet, and clear worksheets.
