We’re excited to announce the 27th release of the Tulip Library!
If you’d like to use this app, click on the app’s link below and install it to your account today!
Release 27:
The Simple Logbook Template is a pre-configured, ready-to-use equipment logbook application. It allows for a facility to create, view, and correct logs of equipment related to events that occur.
The Advanced Logbook Template is an easy to configure, ready-to-use equipment logbook application. It allows for a facility to create, view, and correct logs of equipment related to events that occur. The Advanced Logbook Template has various steps and methods to interact with logs.
Digital System Access Management
The Digital Systems Access Management app allows users to submit requests to gain access to a particular digital system in your operation. Business and technical owners of each system can review access requests, and approve or deny them.
Get started with these apps and more in the Tulip Library.
