We’re excited to announce the 25th release of the Tulip Library!
If you’d like to use this app, click on the link below and install it to your account today!
Release 25:
The Digital Systems Inventory app allows you to maintain a consolidated list of digital systems your business uses, the business and technical owners of each system, and your periodic access review requirements.
Get started with this app and more in the Tulip Library.
