We’re excited to announce the 19th release of the Tulip Library!
If there’s an app, app suite, or connector in this list that you’d like to use, click on the app’s link below and install it to your account today!
Release 19 Apps:
The Safety Cross app digitizes paper-based Safety Cross templates in an interactive, visual tool for collecting data and identifying specific areas for continuous improvement.
The Google Calendar Unit Test allows you to connect your Tulip app to a Google Calendar calendar to view, create, update, or delete events.
The Google Translate Unit Test uses Google’s Cloud Translate API. The connector takes targeted text or languages and outputs translated text.
Get started with these and more in the Tulip Library.
