We’re excited to announce the July releases of the Tulip Library!
If there’s an app, app suite, or connector in this list that you’d like to use, click on the app’s link below and install it to your account today!
Release 22 Apps:
The Light Kit Unit Test app provides a simple way to test that a Tulip Light Kit has been set up properly. Illuminate specific bins to guide operators.
Release 21 Apps:
The Kaizen Funnel enables end-users to submit Kaizen ideas and opportunities, and track submission progress as well.
The Takt Time App Suite makes it easy to record and report on production counts and defects in real-time. The Takt Time App Suite contains 2 apps:
- Takt Time App
- Takt Time Dashboard
Release 20 Apps:
The 5S Checklist app makes it quick and easy to capture and analyze 5S audit data for reporting.
The Looping Unit Test makes it easy to use looping techniques from Tulip Library apps in your own application. Explore how arrays can be used within apps to “loop” steps.
Get started with these and more in the Tulip Library.
