We’re excited to announce the 18th release of the Tulip Library!
If there’s an app, app suite, or connector in this list that you’d like to use, click on the app’s link below and install it to your account today!
Release 18 Apps:
The Vision Unit Tests make it easy to get started with Tulip’s no-code computer vision. Easily configure and experiment with change detection and jig detection.
The Material Request app centralizes material requests into a single, easy-to-use system.
The BOM Management app provides an easy mechanism for managing a bill of materials.
The Material Backflush app enables end-users to automatically adjust inventory quantities for components when an assembled part is added to inventory.
The Google Drive Unit Test enables end-users to create, read, and edit Google Drive files that they have access to.
The Photo Gallery app enables end-users to store photos and videos to a single reference item that can be viewed in a slideshow or gallery.
Get started with these and more in the Tulip Library.
