We’re excited to announce the 24th release of the Tulip Library!
If there’s an app, app suite, or connector in this list that you’d like to use, click on the app’s link below and install it to your account today!
Release 24 Apps:
The Factory Kit Unit Tests allow you to rapidly get started with adding IIoT to your Tulip apps. From setting up and registering the included Tulip edge device to testing and getting acquainted with the individual devices included in the box, this app suite walks you through each step.
Check out the Tulip Factory Kit for more.
The CAPA Management app allows you to capture quality events and CAPAs. Assign the appropriate people to each event and require certain fields as the event moves throughout different states of the investigation process. This app replaces the previous CAPA Management app
The Quality Event app allows you to consistently track and manage quality events and deviations so that you can focus on finding the root cause. Easily view historical and current records to evaluate and manage the effectiveness of your quality event process and focus on continuous improvement.
Get started with these and more in the Tulip Library.
