We’re excited to announce the 11th release of the Tulip Library!
The Library is a set of apps that can be added to your account and used out of the box. Each App comes with an installation guide and a video describing how the App works and what it can be used for.
If there’s an App in this list that you’d like to use, click on the App’s link below and install it to your account today!
Release 11
The Kanban System app provides a framework for creating a system for material management. Define “Kanban loops” consisting of any number of bins/cards to create a replenishment relationship between customer entities and supplier entities.
Try the Kanban System app here.
The CAPA Management App allows you to capture quality events and CAPAs. Assign the appropriate people to each event and require certain fields as the event moves throughout different states of the investigation process.
