Library Release Note - February 2026
Hey Community :waving_hand:
The latest Library release note just dropped.
This oneโ€™s all about making data work harder outside of Tulip, and making your data model easier to expand inside of it.
Highlights:
i3X Connector โ€“ open API interoperability for manufacturing
pdfGeneratorAPI Connector โ€“ custom PDF generation with password protection
9 Table Extensions โ€“ prebuilt columns for calibration, quantity tracking, GHS safety info, and more
:page_facing_up: Full release notes
Questions or feedback? Drop them in the thread :point_down:
Has anyone tried using pdfGeneratorAPI to generate a PDF and then have it saved into a Tulip table record?
Hey @doneil,
The pdfGen API creates a URL for your PDF - you could certainly store that URL into a text type column in a tulip table and use the webpage widget to visualise it. Were you potentially thinking along the same lines or perhaps using a FILE type column for this?
Thanks!
